I believe Nissens does not ship with the rubber grommet but blue box VOlvo does.
The rubber rad grommet is NLA new.
Found it at FCP
https://www.fcpeuro.com/products/volvo- ... vo-1397283
Conjecture - the radiator mount bolts take light torque - only30 Nm. I wonder if the design is the let the radiator float on those mounts so that the end caps dont get stressed by body flex?
1999 V70T5M Nissens Radiator incorrect fitment induced Replacement Failure
aeg
- Year and Model: 97 850GLT
- Has thanked: 2 times
- Been thanked: 46 times
I bought fresh bushings separately when I changed my radiator. Volvo P/N 9180544, two required.rrres wrote: 31 Jul 2025, 10:24 Did your Nissens radiator come with the rubber mount bushings? The Nissens radiator I received, for some reason, didn't come with the rubber mounts and I had to pull the rubber mounts from the old radiator. They were pressed in so I had to slice them a little bit to get 'em out.
- 3365 Views
- 13 Replies
- 4237 Views
Last post by BEJinFbk
- 1005 Views
Last post by Dougherty27
- 740 Views
Last post by precopster
- 15 Replies
- 2805 Views
Last post by cuhfs
