Fuel pump firstly becomes very noisy before it eventually dies.
If it's quiet i wouldn't worry about it,especially if jumping a fuel pump relay makes problem go away.
'98 S70 Jerky hesitation Topic is solved
- misha
- Has thanked: 155 times
- Been thanked: 432 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- dosbricks
- Year and Model: '96 855, '98 S70
- Been thanked: 4 times
OK, it doesn't seem unusually noisy. I have a good 103 red relay from my 850 (purchased while throwing parts at another problem). Is it OK to try that 103 in the S70? They seem to be interchangeable according to FCP's parts catalog.
- Has thanked: 316 times
- Been thanked: 531 times
The 103 relay out of the 850 should be just fine. They should all be the same relay.
- misha
Yes they are.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 311 times
- Been thanked: 817 times
Volvo kept using the same fuel pump relay well beyond the 850 - throughout all P80 cars, then on into several of the post-00 vehicles.
You guys just reminded me I Never cleaned up my relays found at ALbany VolvoFest 2017..
I've had two P80 fuel pumps fail and they never made any noise. They failed abruptly and without warning. I don't think "becomes very noisy" is by any means typical.misha wrote: 14 Apr 2017, 10:07 Fuel pump firstly becomes very noisy before it eventually dies.
- dosbricks
Thanks erikv11. I'm going to drive the car a few days like cn90 suggested with 15-87 jumpered to watch for any hiccups.
The Bosch pump insert came today and looks genuine. At 229k, do you suggest I go ahead and install it even if this turns out to be the relay? We are going to be making some trips in this car this summer.
229k on a factory pump seems impressive. If the car is going on some trips where failure would be a big hassle then I would do that swap, yes. Make sure the rubber check valve seems to be intact still, when you swap the fuel pump insert.
- Been thanked: 504 times
dosbricks,
- Just drive the car a few days with the jumper wire in place.
- The fuel pump: if you only drive locally then I'd leave it alone for now. Just leave the new fuel pump in the trunk just in case.
If you drive long distance, then again carry the fuel pump in the trunk.
It is a toss-up.
- Now, if you decide to replace it (which I think is a good idea anyway), save the old fuel pump in a ZipLoc bag and store it in the trunk for emergency use. New pump can fail too.
- Re fitment: apparently the Bosch 69693 is the real deal, but from my reading of forum, user "stephansvolvo" (search for his posts) had to remove the black casing of the new pump to fit. As you know you need to make sure the polarity is correct. Make note, photos. Also most people say use a new fuel hose (I think it is 8-mm type).
- I replaced the fuel pump cover rubber seal and posted some info, hope you find this DIY helpful:
DIY: 1998 S70 Fuel Pump RUBBER SEAL
viewtopic.php?t=60329
It is a toss-up.
- 6554 Views
- 1096 Views
Last post by ChadLee
- 506 Views
Last post by ignatz
- 35 Replies
- 2034 Views
Last post by vtl
- 345 Views
Last post by phils94850
