ECM-6300 and ECM-6B00 2000 V70R [BAD Battery to fusebox supply cable!] EPIC Troubleshooting Topic is solved
Has thanked: 1610 times
Been thanked: 4065 times
Bulbs were confirmed good above by lighting them up in VIDA
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
abscate wrote: 30 Apr 2019, 23:09 Bulbs were confirmed good above by lighting them up in VIDA
Some times the filaments break then reconnect. Have you not had a light bulb you could tap and make it flicker?
The two codes are listed as Intermittent fault.
Active
Past
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
RickHaleParker wrote: 30 Apr 2019, 23:41 The two codes are listed as Intermittent fault.
They both have listings for both permanent and intermittent faults.
- S
[Sold] '97 S70 T5
RickHaleParker
Sommerfeldt wrote: 01 May 2019, 00:59 They both have listings for both permanent and intermittent faults.
Same difference.
Active
Past
Sommerfeldt
RickHaleParker wrote: 01 May 2019, 01:19 Same difference.
If so, how was it relevant that they're listed as intermittent, then?
- S
[Sold] '97 S70 T5
RickHaleParker
Sommerfeldt wrote: 01 May 2019, 02:00 If so, how was it relevant that they're listed as intermittent, then?
Same difference meaning:
By my statement it should be checked for intermittence because it might be an intermittent fault.
By your statement it should be checked for intermittence because it might be an intermittent fault.
Active
Past
Sommerfeldt
RickHaleParker wrote: 01 May 2019, 02:43 Same difference meaning:
And how would one go about doing that, when there's no cause to be found? I'm pretty sure bmdubya has enough wits about him to try and clear codes and see what comes back. It's the first step in any and all fault tracing.
- S
[Sold] '97 S70 T5
RickHaleParker
Sommerfeldt wrote: 01 May 2019, 02:52 And how would one go about doing that, when there's no cause to be found? I'm pretty sure bmdubya has enough wits about him to try and clear codes and see what comes back. It's the first step in any and all fault tracing.
If it is permanent it will come back. If it is intermittence it will come back.
Clearing the codes gets rid of artifacts not intermittent faults.
Active
Past
I’m assuming that the bulb on steady in Vida and flickering on error code is reproducible, which points away from an intermittent bulb fault. Isn’t there an actually ECM code for the CEL bulb, too?
You guys are both highland skilled detail oriented nit pickers which is why you-plural excel as troubleshooters, even if you talk past each other a bit
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Neither is picking nits this time around, one of them is just never, ever wrong ... even when he obviously is.
