brake noise
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
I'm not familiar enough with the function of the part to say whether if it is having problems such as hanging up, can cause noise during soft vs braking hard. However, if the fluid has uneven pressure you should feel some pull here or there for sure?
jantt
Year and Model: C70 2000
Been thanked: 2 times
Post by jantt »
Problem solved
Mounted anti squeke plate back on half the pad front
Two days without noise
MoVolvos
Post by MoVolvos »
jantt wrote: 29 Jun 2019, 03:37 Problem solved
Great News! Did you put any Brake & Caliper Grease on A & B before the shims? Which side A or B did you put the shim on?
https://www.crcindustries.com/products/ ... L3301.html
C70 2000 BRAKES.png (159.61 KiB) Viewed 652 times
jantt
Post by jantt »
No grease back on A or B
Shim on both A and B
Had put plate on pads before, but the trick was to only put it only on half the pad to get an angle
