No heat to the floor 96 850R with climate control
Fix Heat for the Volvo Damper
I had to take a moment to register so that I could thank those of you who took the time to troubleshoot and post a fix for the heater flap /motor problem.Thankfully the shaft on mine was intact but cracked. The flap was seized and after some time working the shaft, it freed up and I was able to rotate the shaft and move the flap as normal.Guess I was lucky that it didn't burn out the servo motor. I happen to have a spring/compression type hose clamp that fit snugly over the cracked shaft which I installed and secured with a couple of drops of Loktite super glue.
http://www.impalas.com/1955-1968-chevy- ... hc001.html
My wife thanks you for warm feet again!
cheers, doug
cheers, doug
- 3843 Views
- 6731 Views
- 2039 Views
Last post by brendonrobar
- 1041 Views
Last post by blandis
- 3903 Views
Last post by Ozark Lee
