Clean and reset the electrical connector first.
Vida 2014D Times out 12/31/2017 23:59 Topic is solved
- RickHaleParker
- Been thanked: 977 times
Active
Past
Past
- RickHaleParker
Yes clear the codes.
The only way you will know if it fixed the problem is to clear the codes and see if they come back.
Active
Past
Past
60cents
- Year and Model: 2005 xc70,2004 S60R,
I'm trying to find the VIDA 2014D-RePack file.
Does anyone know where to look?
The link in RickHaleParkers post above doesn't work.
It takes me to google translate and then google won't connect to the store.
- RickHaleParker
Use the Alternative instructions and Magnet link on page 16. The hyperlinks are all dead now.60cents wrote: 13 Apr 2021, 14:48 I'm trying to find the VIDA 2014D-RePack file.
Active
Past
Past
Hi Richard,RickHaleParker wrote: 27 Jan 2019, 06:24 DiNCA Something minor did not go right on your install. There is an easy fix, Locate C:\VIDA\WslLogin.exe.
and rename it to WslLogin.exe.bak Reboot then login as admin.
I have the same message however when I go to C:\VIDA I dont see C:\VIDA\WslLogin.exe. listed only WslLogin.exe.bak
which is a 65kb BAK file. Not sure what to do, any advice? thx
Dale
- RickHaleParker
What have you done and tried?dedubyah wrote: 27 Apr 2021, 19:00 I have the same message however when I go to C:\VIDA I dont see C:\VIDA\WslLogin.exe. listed only WslLogin.exe.bak
Did you try login in as admin after renaming the file and rebooting?
Active
Past
Past
- 7992 Views
Last post by jonesg
- 5184 Views
Last post by matthew1
- 4467 Views
Last post by Liliflower
- 10263 Views
Last post by nickbw898
- 2713 Views
Last post by xiami
