Vida CEM swapping
Dudde
Year and Model: 2005 V70 and more
Has thanked: 17 times
Been thanked: 17 times
Post by Dudde »
Treur wrote: 22 Dec 2024, 05:20
Dudde wrote: 22 Dec 2024, 05:19
Treur wrote: 22 Dec 2024, 05:17 Does anyone know how the odometer is generated in DIM?
What do you mean? How to change the mileage?
Yes
What DIM do you have? Year?
Treur
Year and Model: 2007 V70
Has thanked: 3 times
Been thanked: 7 times
Post by Treur »
For example xc90 2007 with mcu mask 0L85D
Treur
Post by Treur »
I think, the algo is +/- same in all DIM
Dudde
Post by Dudde »
Treur wrote: 22 Dec 2024, 05:25 I think, the algo is +/- same in all DIM
I'll get back to you on this when i have my laptop, don't remember exactly how to do it. But there are software for it and also it is not hard to do it in hex editor.
Treur
Post by Treur »
I no need to change, I need convert odo data from eeprom to int value
scaro
Year and Model: Volvo&Audi
Has thanked: 14 times
Post by scaro »
Treur wrote: 22 Dec 2024, 03:10
Dudde wrote:
Read UEM with im608 and program remote
Only new with codes label.
Someone have any clue how to program used fobs? I know its possible if you have the old UEM with keyfob to move fobinfo from UEM to another used UEM. But thinking of keyfob without known UEM? Theres a encryptioncode i think is needed for it to work afaik?
244 Turbo (86K miles) 1983
242 B230FK, Rollcage, LSD 1984
244 B21A with R-Sport Turbo-kit 1980
A5 2.0TFSI Quattro Conv. 2012
A4 1.9TDI 1997 BV43, 11mm vp37, 0.26 nozzels, 6speed, A8 brakes front, S4 discs/calibers rear
A4 1.9TDI 1998 Daily
Treur
Post by Treur »
It's impossible
haifisch
Year and Model: 2002 S60, 2006 XC90
Post by haifisch »
Treur wrote: 22 Dec 2024, 02:36 For cloning you must remove cem from car, and transfer data from MCU and eprom to other cem. I use China xprog for MCU and tl866+ for EPROM.
Thank you! Do I have to desolder the chips to read/write them or connect these tools to some pins on the CEM? I am experienced in programming but only things like web development, SQL, etc or sysadmin stuff. I am noob in embedded systems like ECUs but I am interested(in this field and also in saving my CEM) :D
Treur
Post by Treur »
haifisch wrote: 23 Dec 2024, 07:17
You don't need to desolder the mcu, just eprom.
Rolton
Year and Model: 2006 V70R
Has thanked: 1 time
Post by Rolton »
Hello,
2006 V70 CEM - 31394157
Trying to get my CEM pin using T5Luke's UDScrack
Getting bunch of errors, not sure if it's working right
