Name that rusty part
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Elsewhere on the Forum there is a 'torque chart' that specifies 35 ft/lbs for the oil pan drain plug. I would propose that is a tad too tight.
- Has thanked: 2203 times
It is 35 Nm NOT 35 ft/lb.
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
When I was doing my timing belt, I was checking several sources. I even check the conversions in the Volvo documentation, as it's not always correct either. I found at least one spec, where the SAE and SI values were not equal to each other.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
That's fair. I work on that ft/lb = 75% Nm. It's very close. So your oil pan is 35 Nm = approx. 26-27 ft/lb. Don't want it tighter than that as you said or you crush the crush washer too much and remove the sealing properties!!
- FireFox31
- Has thanked: 159 times
- Been thanked: 303 times
That oil pan plug was probably torqued to double the 35 Nm spec. I almost had to get out a breaker bar to remove it. It was brake caliper bracket bolt tight. No wonder the plug was wearing the crush washer like a second skin.
FireFox31
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Grunhilde? =P
I'm thinking oil filter bracket, at some point in its life.
- Been thanked: 4068 times
Jreed for the win, it was a rear bumper bracket.
Bonus round, which side?
- wizechatmgr
Driver's/left
- FireFox31
The notch is a giveaway on the bumper bracket. Are they are mirrored for each side? I'd say it's the right / passenger's side because I've seen two P80 rear bumpers retaining more water on the right side, ruining that bracket worse / faster than the left. Really makes me want to drill drain holes in the bumper metal. I think Robert DIY did that.
FireFox31
- wizechatmgr
It's funny you mention that, my rear right is precisely where my droop has started on my XC.FireFox31 wrote: 31 May 2023, 15:12 The notch is a giveaway on the bumper bracket. Are they are mirrored for each side? I'd say it's the right / passenger's side because I've seen two P80 rear bumpers retaining more water on the right side, ruining that bracket worse / faster than the left. Really makes me want to drill drain holes in the bumper metal. I think Robert DIY did that.
- 4406 Views
Last post by 93Regina
- 1757 Views
Last post by oragex
- 713 Views
Last post by voom8
- 2358 Views
Last post by seanj
- 23 Replies
- 6341 Views
Last post by Phantomphixer
