DIY: 1998 V70 Axle CV Rubber Boots Tips/Tricks
This topic is in the MVS Volvo Repair Database » Do It Yourself CV Boot Repair - Volvo V70
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
These things should be in a museum, Works of art...great job!!!!
youropeen
Year and Model: 2007 V70 R/2005 XC70
Post by youropeen »
Both boots are torn on torn on my driver's side axle. I'm contemplating on getting a replacement and DIYing this job. Would I need to also replace this (http://www.fcpeuro.com/products/volvo-a ... -6843112-1) seal on the transmission?
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
I like to replace the seal when I pull an axle, unless I know it is relatively new.
You don't have to buy the Volvo brand to get quality on this part, it is just a rebranded SKF axle seal
http://www.fcpeuro.com/products/volvo-a ... al-6843112
youropeen
Post by youropeen »
Thanks Erik!
Can I assume that if I pull the seal that I will lose some fluid and by doing so it would be a good time to do a fluid change anyway?
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
I replaced the axle seals on my '97 855 GLT a couple months ago at ~165k miles. I was working on an slightly sloped driveway. I was surprised how much transmission fluid leaked out on the downhill side -- it was probably 1 liter. On the uphill side axle, very little or no fluid leaked out when I pulled the seal.
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
The driver's side will loose fluid after axle is pulled.
My 2001 V70XC lost close to above 2qt in 24 hours while all 4 wheels were on jack-stand.
I will not rush to save, rather make it a simple D&F.
ps - I can not feel gear shifts up or down, only RPM reflects the change (@150K - this was 7th D&F in 2 years). Love it!
Post by erikv11 »
What those guys said ... yep, good time change out some fluid.
mecheng
Year and Model: 1998 Volvo S70 T5
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
I was changing to my winter tires and it looks like I may be the exception to the rule, my drivers Inner Boot is leaking grease from a crack in the boot. Outer boot is fine. Volvo OEM axels, not sure if PO repalced boots. I used a syringe for Childrens Tylenol and squeezed in lots of lithium grease and then sealed it with RTV silicone sealant to buy some time. Heck, it might even last for a while as the inner joint doesn't flex much.
My local parts supplier is able to source the GKN outer boot for a 98 t5 (Part number 31256240) for only $20 but not the inner boot (PN 31256230). The Volvo dealer wants $59 for the inner boot; which might be worth it as I don't want to have to do this twice?
How is everyone's inner boot made by EMPI or Rein boot holding up?
Where are they made?
Not sure if the inner boot on the car now is GKN, I see Germany stamped on it. Could it be Rein? Maybe PO replaced it? Thanks
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
You can use OUTER boot for INNER side.
mecheng
Post by mecheng »
cn90 wrote:You can use OUTER boot for INNER side.
Is their any write up on it, I see that you briefly mention it in one post but has anyone took the measurements? Why would they sell a different boot for the inner?
Thanks
