By the way, I didn't just finish. I finished at 7pm MST and called it a day. Here's the pics:
Man am I having a heck of a time getting off the 36mm nut
- Has thanked: 2856 times
- Been thanked: 1332 times
I'll find out if the LF is good in the morning.
- Pry bars. This was actually the easiest of everything I did. The inner axle just popped out.
- 850-suspension-rare-expensive-prybars.jpg (181.97 KiB) Viewed 1992 times
THIS Picture happens to show cracked rubber brake line, and that is where I was told they break and leakwheelsup wrote:Is this what you were having difficulty with?
You really need to get air. An air hammer with a pointy attachment would've made short work of that. Just rubbing it in.
99 V70XC 158K
95 850glt 188K
95 850glt 188K
obayha
- Year and Model: V70 1999 Base
- Been thanked: 2 times
So this project was to change out the hub bearing???
Is this a maintenance thing or was something wrong?
I know I ask a lot of question, but I have an axle swap coming up and want to know if I need to plan on doing the hub at the same time..
Thanks for any input.
Shane
Shane
1998 V70 T5 331,000
Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
Obayha, the hub was going bad. Whump whump whump as I turned right, meaning my left hub, or one of them, was going. At 250k+ miles you might want to do preventative hub replacement, but they're not in the preventative maintenance price league at $100-ish times four.
My mistake was to ruin the axle by hammering it too hard with too hard a sledge. Perhaps they make 40lb. rubber hammers and this wouldn't have happened if I'd used one.
Without my mistake, things might have gone just fine, and much faster. I would have done the control arm and axle in a few weeks, after increasing my toolset properly, for the jobs.
I took her for a test drive just now, everything's fine.
Xilikon
- Year and Model: 2000 V70 XC SE
Yeah, change those hoses !! I did on mine and some parts are a pita to work with the rust (East Canada winters and road salts !!).Pauloil wrote:THIS Picture happens to show cracked rubber brake line, and that is where I was told they break and leakwheelsup wrote:Is this what you were having difficulty with?
2000 V70 XC SE with 150,000 miles, still going great !
obayha
Thanks for the wheel hub info. I will hold off until I hear the Whump,Whump, Whump.I need to fund my axle change first. I'll miss the 50-70 mph vibration when it's gone
. You get use to stuff being there and when you fix it.. it's like.. now what?
Shane
Shane
1998 V70 T5 331,000
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Then something else goes wrong. Such is your life owning a Volvo.I'll miss the 50-70 mph vibration when it's gone. You get use to stuff being there and when you fix it.. it's like.. now what?
After we changed the sway bar links on my car a few weekends ago, I think the right one's loose again. I tried futzing with it last night, and didn't touch the left wheel AT ALL, and now it's making some odd noise from that side. It did drive AWESOMELY for about 2 weeks though before I think the bolts loosened up again
'98 S70 T5
2016 Chevy Cruze Premier
Same thing happened to me. I put some mild thread locker on it the second time around.jblackburn wrote:
obayha
Off 36mm subject.. but did I read on here to tighten the strut nuts with an impact???
Maybe just to much reading during working hours
I would like to say that my Trax/ABS lite has been off after the third try at fixing it.. But then it will be back on today or soon..
This site has been great at teaching me a lot about my Volvo.
Thanks
Shane
Thanks
Shane
1998 V70 T5 331,000
wheelsup
- Year and Model:
- Has thanked: 16 times
- Been thanked: 22 times
That car is long gone, sold for scrap...Xilikon wrote:Yeah, change those hoses !! I did on mine and some parts are a pita to work with the rust (East Canada winters and road salts !!).Pauloil wrote: THIS Picture happens to show cracked rubber brake line, and that is where I was told they break and leak
- 775 Views
- 1276 Views
Last post by precopster
- 1073 Views
Last post by zombielinux
- 936 Views
Last post by Redbox
- 836 Views
Last post by 850TurboTurtle
