I won't be able to attempt turning the engine over until I can get my friend's breaker bar. on Tuesday I will remove the starter and attempt to turn the engine if possible.scot850 wrote: 19 Jun 2020, 16:17 Have you tried to remove all the spark plugs and manually turn the engine over? If you thing the started has seized, remove that before trying this and see if the engine has frozen. No point condemning the engine to quickly. Removing the starter will also not be wasted as you will need to remove it if the engine is wasted anyway. Can you borrow a boroscope? If you can you can put it down the plug holes and look for damage on the piston crowns and broken rings. Also check the crown wheel teeth for damage where the starter motor was when it seized (assuming it did).
I am ever the optimist and hope that your engine is not done!
98 XC: VERY bad starting sound after replacing injector seals
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Make sure those plugs are out first - that gas needs a place to go...CIK7 wrote: 19 Jun 2020, 16:59I won't be able to attempt turning the engine over until I can get my friend's breaker bar. on Tuesday I will remove the starter and attempt to turn the engine if possible.scot850 wrote: 19 Jun 2020, 16:17 Have you tried to remove all the spark plugs and manually turn the engine over? If you thing the started has seized, remove that before trying this and see if the engine has frozen. No point condemning the engine to quickly. Removing the starter will also not be wasted as you will need to remove it if the engine is wasted anyway. Can you borrow a boroscope? If you can you can put it down the plug holes and look for damage on the piston crowns and broken rings. Also check the crown wheel teeth for damage where the starter motor was when it seized (assuming it did).
- CIK7
no gas in chambers. intake Port#2 from passenger side and entire intake manifold was full of gas.wizechatmgr wrote: 26 Jun 2020, 18:40Make sure those plugs are out first - that gas needs a place to go...CIK7 wrote: 19 Jun 2020, 16:59I won't be able to attempt turning the engine over until I can get my friend's breaker bar. on Tuesday I will remove the starter and attempt to turn the engine if possible.scot850 wrote: 19 Jun 2020, 16:17 Have you tried to remove all the spark plugs and manually turn the engine over? If you thing the started has seized, remove that before trying this and see if the engine has frozen. No point condemning the engine to quickly. Removing the starter will also not be wasted as you will need to remove it if the engine is wasted anyway. Can you borrow a boroscope? If you can you can put it down the plug holes and look for damage on the piston crowns and broken rings. Also check the crown wheel teeth for damage where the starter motor was when it seized (assuming it did).
- Has thanked: 2203 times
If that is drained out or vented off, with all the plugs out will it then turn over by hand?
- Has thanked: 987 times
- Been thanked: 1075 times
CIK7, any progress on troubleshooting?
Hardtofool
- Year and Model: V70XC 2000
What kind of injectors did you buy? Where they oem?
