Do it yourself ABS module repair. Topic is solved
This topic is in the MVS Volvo Repair Database » Do It Yourself ABS Module Repair
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
kaneelschep wrote:Ah. I just checked out the wiring and found that the seperate two-lined cable has completely deteriorated. Well the insulation that is.
Has anyone discovered how to get the plastic black cover of the Abs pump? Then I can renew the cable's insulation all the way.
I have been fortunate enough to not have that problem (yet). Check with member Matty Moo, he has seen it all and if there is a fix he knows the best way to go about it.
https://www.matthewsvolvosite.com/forums ... le&u=13052
Hopefully he sees this and comments back, you aren't the first one to have the problem.
Matty Moo
Year and Model: 850, 1996
Has thanked: 1 time
Been thanked: 30 times
Post by Matty Moo »
There are two tabs that hold that cover on, pry on the cover with a screwdriver, you'll then see where the two tabs are then pull it off. Then re-wrap each wire individually with rubber tape.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
bjmcc1984
Year and Model: 97 850 GLT/2006 XC70
Post by bjmcc1984 »
So I know this was from 2008, but a Chapman set made it really easy for me to remove the module.
http://www.chapmanmfg.com
https://www.amazon.com/Chapman-5575-Scre ... B00682RIAY
joe_pinehill
Year and Model: 850 1996
Post by joe_pinehill »
I replaced the torx head screws with stainless steel socket head from McMaster Carr.
96 850 GLT
RIP '90 240 DL, 285K, someone ran a stop sign in front of me
RIP '89 760 Wagon, 200K
RIP '83 240 Wagon, rusted out
Has thanked: 1609 times
Been thanked: 4065 times
Joe..would you mind posting part numbers for the SS bolts to this thread please
joe_pinehill
abscate wrote:Joe..would you mind posting part numbers for the SS bolts to this thread please
here's what I ordered McMasterCarr:
92290A188 Metric 316 Stainless Steel Socket Head Cap Screw, M4 Thread, 50mm Length, .7mm Pitch, packs of 10
92153A418 Metric Type 316 Stainless Steel Split Lock Washer, M4 Screw Size, 7.6mm OD, 0.8mm min Thick, packs of 100
I will probably never use the 6 extra I have, email me off line, if you like, I can mail 4 screws to you, if you paypal the shipping, I would put them in a flat rate priority envelope.
96 850 GLT
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Is this thread available in BOOK format? Really, 32 pages and 447 post (make that 448)? I heard about someone opening a can of worms but wow! I think Lee has set a record here. I'll go by the trophy store and see if they have a S70 topper and try to get an award built. :p
tadmania
Year and Model: 2001 S40
Post by tadmania »
Perfect help. I followed your lead (even marring up the casing during disassembly) soldered the leads and, ta da !!!, it works just fine. Thanks!!
cresson
Year and Model: 850 '92 2.5 20V
Post by cresson »
Ozark Lee wrote:The early version ABS controllers rarely fail. Most of the problems with the early system are due to wheel sensor connections, etc. Pull the codes from port A-3 and post them back.
yeah, it's quite a old comment but mdempst_79 didn't posted his codes so I will share mine :D
4-4-4 - No Supply To Hydraulic Unit Valves
3-1-2 - Right Front Wheel Sensor, Open Or Short Circuit
3-1-3 - Left Rear Wheel Sensor, Open Or Short Circuit
and 1-2-2 - Right Front Wheel Sensor, Circuit Fault At Speeds Less Than 25 MPH
symptoms? the hydraulic pump turns on randomly, in most cases I'm not even touching the brake pedal.
when it activates during braking it brakes like it during skidding
Could you give me some hints/ideas, where i can start :roll: ?
thank
850 2.5 20v 125kW 12.1992
Post by Ozark Lee »
Step one is to clear all of the codes and see which ones come back. The modulator pump is obviously getting power or it wouldn't activate as you describe with your the symptoms.
Clean all of the wheel sensors and the reluctance rings on the axles (front) and hubs (rear). The rears are a bit tougher since the rotor needs to come off and you will need to adjust the parking brake both while removing the hub and after you put it back on.
Other than that, check all of the connectors and inspect the wires from the wheel sensors.
