What has failed on your 1992-2000 FWD or AWD Volvo?
- Has thanked: 2865 times
- Been thanked: 1332 times
Unstickying this and tucking it inside Links to MAJOR forum topics - 850, S70, V70, C70 & V70-XC to keep the top of the topic list from growing too tall. That will remain at the top of the forum.
precopster
- Year and Model: Lots
- Been thanked: 128 times
B4 servo cover failed on my 2000 V70 non turbo (P80) causing 2nd-3rd gear flaring
Replacing it solved most of the shift problems though solenoids are sticking causing occasional bumping when downshifting.
nielstroll
- Year and Model: V70 1998
Guys, when I approached the forum on my ABS failure, the responses (ABS module, sensors, damaged tooth cam) were all tested and found to be ok, or not to be responsible. The problem however, remained. Only last week did the computer identify a hydraulic pump failure as a possible new cause. Tested the pump, found it ok. Last remaining option: the printed circuit board controlling its action. Lo and behold, two failed solder connections have nagged me for a few years. As a possible reason for the failure an overheated hydraulic pump was mooted. All problems now gone, speedo and odo, as well as cruise control all working fine again. Thought I would let you guys know.
95 850 - Climate Control sensor sometimes goes nuts, ABS ring on passenger side CV Axle came loose causing all sorts of ABS issues, Leaking radiator and oil cooler lines.
98 V70 - Rear/side defrosters don't work, steering rack showing signs of going bad, driver seat seams coming undone from alcantara/leather. Oh, and the whole it doesn't run when in closed loop mode.
98 V70 SE T5 - ARD Green Stg2|Bosch Blues|FSDs|IPD Blues|Volans
95 850 Turbo - Daily/Beater/Workhorse
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
#1 failed item on my 92-200 Volvo: Previous owner(s)
Current Volvos:
joe_pinehill
- Year and Model: 850 1996
This tells me these are very very reliable cars. (knock wood)
96 850 GLT
RIP '90 240 DL, 285K, someone ran a stop sign in front of me
RIP '89 760 Wagon, 200K
RIP '83 240 Wagon, rusted out
- charleskennedy23
- Year and Model: 1998 V70 T5
Rear shocks and front struts...
Charles Kennedy
"HAGRID": Black '98 Volvo V70 T5
- 1620 Views
Last post by foggydogg
- 2538 Views
Last post by RickHaleParker
- 804 Views
Last post by ddavis6900
- 2668 Views
- 2398 Views
