would water pump work without timing belt HoopLa...
rspi
Has thanked: 34 times
Been thanked: 72 times
Re: would water pump work without timing belt HoopLa...
Post by rspi »
I really don't know other than to say, use a good bit. I have messed a few up so I don't have the best method.
rspi
Post by rspi »
Here is my lecture on what should be replaced on a timing belt job.
Year and Model: 2004 V70 2.5T
Been thanked: 476 times
Post by cn90 »
rspi wrote:Here is my lecture on what should be replaced on a timing belt job.
Great video but I don't see a Multiple-Choice Exams at the end haha.
Post by cn90 »
xHeart wrote:...Now that the water pump is off, I am moving to removing the T45 on the roller. With a 3/8 adapter, I would use a 15mm combination to fit the space. So I have solve the tight space problem. I Would pull it from 3 o,clock to turn it counterclockwise. Is there a better method, wrench position, or tooling?
I guess you can use Sears Craftsman tool, if broken get new ones for free.
Harbor Freight sells a "Serpentine Belt Tool" with 3/8" square but the handle is very very thin, so it fits in that space very well. Just make sure the Torx recess is clean (use a small screwdriver to clean the inside of the Torx hole to remove debris). If debris is there, it prevents the Torx bit from fully seated ---> stripping the bolt.
This is true every time you deal with Torx or Allen head: remove debris first!
Here is the HF Tool for $18. If you own a Honda, you want to own this tool too:
http://www.harborfreight.com/serpentine ... 66344.html
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 116 times
Post by xHeart »
rspi wrote:I really don't know other than to say, use a good bit. I have messed a few up so I don't have the best method.
I am using similar to your good bit example in 3/8" drive.. Would a breaker bar a better choice with this bit? What about allen style torx key?
rspi
Post by rspi »
The goal is to NOT strip the torque screw on the tensioner roller. If the bit is a good quality bit and doesn't have the rounded tips you will likely be ok. I have used the allen style tools with success on other things like the thermostat housing. Just put the tool in the head of the T45 and put a breaker bar on it. Either use a breaker bar directly on it or point the handle of it away from you and put a box end wrench on the shaft and put a breaker bar on that. Just don't strip the inside of the screw.
@ cn90: We're working on the tensioner roller for the timing belt not the serpentine belt.
xHeart
Post by xHeart »
cn90 wrote: I guess you can use Sears Craftsman tool, if broken get new ones for free.
Craftsman hand tools are excellent. The local sears have started to clean out their tools section. I see fewer each time I go there. Very weak selection in Torx tools.
xHeart
Post by xHeart »
cn90 wrote:Just make sure the Torx recess is clean (use a small screwdriver to clean the inside of the Torx hole to remove debris). If debris is there, it prevents the Torx bit from fully seated ---> stripping the bolt.
Absolutely golden cn90. T45 gained a millimeter, and with a study and increased pull it broke away from 3o'Clock position. The tensioner roller is off.
I will take off the back cover next, before cleaning water pump mating surface. I remember you or Robert pointed to a link on removing tb back cover.
Would the replacement pass MVS Mavericks ipdusa timing belt kit with tensioner and idler bearing, and...
ipdusa water pump kit aisin
Many thanks!
rspi
Post by rspi »
Hurrah!!! Glad you got that tensioner roller bracket off. Was the roller good or loose?
Wasn't me on the back timing belt cover. I've enver taken it off. Why take it off? I'm sure you will have to remove the cam sprockets which will create a dangerous timing cam situation. You currently have the cam locking tool in place which would have to come off.
xHeart
Post by xHeart »
rspi wrote:Hurrah!!! Glad you got that tensioner roller bracket off. Was the roller good or loose?
I will compare these with the new.
Removing tb cover could help with cleaning the water pump mating surface. It would reduce early failure.
I looked at the pump that was removed, the sloppiness is visible to blind. Why set for less if I could be done properly?
