Hesitation on WOT (V70 2.0 T5 AWD 1997) Topic is solved
Fiodor
Year and Model: 1997 V70 2.0 T5 AWD
Has thanked: 13 times
Been thanked: 9 times
Post by Fiodor »
Update : I've noticed that my car stumbles at idle. It's not new but I considered it as normal behaviour before and I think it might be part of the symptoms. And unplugging the MAF doesn't change anything regarding the idle stumble.
I've also noticed that the 5th cylinder's "plug hole " is very dirty compared to the others. I don't know if it could be related.
I haven't done the PCV but the glove test and the dipstick test were both negative.
1997 V70 T5 2.0 AWD with welded angle gear at 240k km
1990 740 Break (dead)
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
What you mean by dirty?
Covered with oil?
When spark plug is removed or not?
Besides the sp.hole....is spark plug on that cylinder also dirtier than others?
What about oil consumption on 1000km or between changes?How much?
After a short drive in high rpm...they ALL should look dry and light grey(the electrode and prongs).
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Fiodor
Post by Fiodor »
Update!
After replacing the spark plugs with volvo OEM and the ignition wires with Bougicord my problems are now gone!
No misfire at idle and a smooth acceleration.
Thanks for your help!
Has thanked: 1610 times
Been thanked: 4068 times
Volvo horns to misha, with a small set to me...
Another one solved by Volvo plugs and Bougicord wires.
