mdr1220
Year and Model: 1996 850R
Has thanked: 44 times
Been thanked: 7 times
Post by mdr1220 »
foggydogg wrote: 10 Jun 2021, 20:37
mdr1220 wrote: 18 May 2021, 19:48 Busted pump removal
Holy mustache, I just stumbled onto this earlier post. Natty Boh Tall Boy ! You are a true Boy from Bal'mer !
That takes some of the pain out of the wrenching.
Born and bred. Perfect beer for working on a car, low alcohol but multiple trips to the bathroom.
Used to have a 01 c70 convertible
brunocerous
Year and Model: 1998 V70
Has thanked: 303 times
Been thanked: 43 times
Post by brunocerous »
I finally reattached the left front mud guard on the Silver Bullet, which had been hanging by a single rivet at the top.
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
Those POM rivets are great for those. I’ve tried the cheap little auto store body clips, but they always fall out. I redid all of mine with those rivets a while back and they’re finally solid!
bmdubya1198
I finally dropped the subrame in the V70R the other day to replace my horribly leaking O’Reilly reman rack. Put the subframe back in today and torqued down the new bolts. Now tomorrow I need to sit the engine back down on all the mounts and get everything else wrapped up. New TRW reman rack is in (hurt my wallet a little bit, but I shouldn’t have to worry about it anymore) as well as Kaphlenke/BNE delrin subframe bushings. Those should be a big improvement over the old rotted out bushings.
Next project with this car will be the delta link swap... finally! I can’t wait to get that knocked out, and I will certainly post something either on here or Swedespeed (or likely both) to document it, since it has not been documented as of the last time I searched. It shouldn’t be too big of a deal, the chassis is exactly the same (as far as mounting locations) on the AWD as the FWD from what I can tell.
mdr1220
Post by mdr1220 »
Got the timing marks lined up. Cleaning and new belt tomorrow.
Any ideas for easy crank pulley removal with hand tools?
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
mdr1220 wrote: 12 Jun 2021, 18:40 Got the timing marks lined up. Cleaning and new belt tomorrow.042.jpg
Does the crank pulley need ro be removed? There is usually just enough space to squeeze the new belt in. Last time I just cut the old belt out. Not having to remove the crank bolt is a big time saver if you can avoid it.
Has thanked: 1613 times
Been thanked: 4078 times
I’ve always zipped them off with a 30mm on an impact, worst case 28 seconds of propane heat needed too.
brunocerous
Yesterday on an errand, I was surprised to find that almost all the resistance in the Silver Bullet’s clutch had disappeared. It now needs a feather-touch to shift, although I have to rev it quite a bit to get it moving in first gear.
As far as I know, it’s on the original clutch (190k). Looks like I have some work ahead of me!
mdr1220
Post by mdr1220 »
ZionXIX wrote: 12 Jun 2021, 22:16
Thanks, Thanks I will give a try.
mdr1220
Post by mdr1220 »
Got to clean this area
The shiny stuff is the metal from the ps pump bearings
Got to work and was surprised how much space was behind the lower timing cover.
