DIY: 1998 V70 REAR Cam Seals using SKF 11809 9443310
This topic is in the MVS Volvo Repair Database » DIY: 1998 V70 REAR Cam Seals
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
If you find a repair fitting the "core" class then ONLY use Volvo parts. Else, oem and aftermarket may just serve the immediate and short-term need.
CORTECO is recommended for CAM seals - superfluid application. Someone wrote, SKF are best in HIGH viscosity applications - example: bearing, axle, drive shaft, angle gear, FD etc.
I've 50,000 miles on CORTECO.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Good to know, I'll probably go with Corteco. eEuro carries them for under $6/piece.
xHeart
Post by xHeart »
There is also consensus among MVS that a Volvo with 100,000 miles is ready for PCV service, IF neglected, CAM seals too are at risk of failing.
bmdubya1198
xHeart wrote: 24 Oct 2018, 09:32 There is also consensus among MVS that a Volvo with 100,000 miles is ready for PCV service, IF neglected, CAM seals too are at risk of failing.
Yup, I did the PCV service a while back... before I even had the car registered. About 20k miles ago.
xHeart
Post by xHeart »
cn90 wrote: 12 Jan 2018, 20:48 ...
- So my 2 cents: stay away from the Volvo OEM seals, stick to SKF or Corteco, but I may be wrong. Anyone with long-term experience (preferably > 80K miles) on whatever seal, please post.
Reading this thread once again in preparation for replacing rear exhaust seal in our 2001 V70XC as a part of PCV overhaul. I'd replaced one in our '97 850 with Volvo's, which now has 60k+ miles on it. For 2001 V70XC it is PN 9443310 with CVVT in front.
Observation: The rear sealing ring goes over the camshaft. My 28mm socket's relative ID matches the camshafts's OD - goes over nicely. For the initial press, I'll thread a longer M7 bolt to cam through the 28mm socket (the screw used for intake manifold is M7 x 30, it is a same thread pitch). FWIW, the 36mm socket slides over the 28mm socket perfectly to continue with the seating of sealing ring.
What is Camshaft OD?
Has thanked: 1610 times
Been thanked: 4068 times
Make match marks on the relict or plate and distributor rotor on the intake rear cam , for you -1998 guys.
I did a job a few years back and found these parts will go back together incorrectly indexed, which cost me three weeks of part time crank, no start troubleshooting
bmdubya1198
abscate wrote: 19 Jan 2023, 04:00 Make match marks on the relict or plate and distributor rotor on the intake rear cam , for you -1998 guys.
Yep, my cousin learned this when we did his timing belt a few months ago.
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
