2005 s60 R
Wastegate was removed.
Wastegate was put back on.
No reference was kept as to the position of the rod (aka the amount of tension).
QUESTION IS: is there anyway to find the correct position/amount of tension OTHER than any electronic tool or reader?
Wastegate Readjustment 05 s60R
renegade420
- Year and Model: 2006 s60r
- Been thanked: 3 times
renegade420
My apologies but any chance you could elaborate on that just a tad more? Where would I be looking for this moon gap to appear?jonesg wrote: 20 Jan 2023, 12:16 I did mine visually, pull the actuator arm until a sliver of a crescent moon gap shows.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
disconnect the actuator rod from the wastegate arm, pull the rod out and place it on top of the wastegate pivot with the wastegate fully closed, pull it far enough that a gap shows at the far side, away from the vacuum motor. Only a small gap is needed, its to provide some pre-tension and prevent the wastegate from rattling also. see this.
- 1908 Views
Last post by rspi
- 2410 Views
Last post by paul c
- 2791 Views
Last post by Switchemlee
- 13 Replies
- 5467 Views
Last post by bmdubya1198
- 14 Replies
- 2864 Views
Last post by Sommerfeldt
