I get a CEM-8F21 code. . . wiper signal problem
When I turn the stalk to intermittent wipers, the wipers go high speed.
I monitored the parameters in VIDA. The high speed relay is activated.
When I push the stalk down one more click, The wipers remain on high speed and the front washers run continuously
In VIDA, the parameters match what happens.
I tried activating front wipers with VIDA and the front wiper ran at low speed.
I tried changing the wiper relay and high speed relay. No change.
Should I go to the junkyard and get a SWM along with the turn signal & wiper stalk. . . for like $40 and a wiper motor for
around $30.
How do I narrow down exactly what the problem is with the front wipers until I start throwing parts at it?
How do I narrow down the problem with the rear wiper?
ALSO. The rear wiper does not work at all. No sounds from the rear door.
- Don Reiher
2005 XC70 need help diagnosing wiper problems
Thanks! I had to replace both the left turn signal stalk, and the right wiper stalk (one from a salvage yard, one from ebay). All the problems I was having went away. The right turn signal now works and no longer turns on the hi beams, and all the wiper functions now work.
- Don Reiher
- Don Reiher
- 12 Replies
- 2300 Views
Last post by 1997volvo850
- 513 Views
Last post by 850 LPT
- 1121 Views
Last post by MIB
- 1073 Views
Last post by d3xter
- 209 Views
Last post by Vova585
