Correct brake fluid
02V70
Year and Model: 2002 V70XC
Has thanked: 53 times
Been thanked: 40 times
Post by 02V70 »
I noticed that the manual says dot4+ brake fluid with 536F boiling point required but it seems that it does not exist.
I already bought this Prestone Dot4 fluid with a 496F boiling point.
is this ok?
The most expensive fluid available at my local auto parts store is
Liqui Moly SL 6 DOT 4 with a higher boiling point of 514F and is low viscosity.
Should I return the fluid I already bought and get this instead?
2002 v70 X/C 288k miles
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
I’ve used this stuff:
ATE Original TYP 200 Racing Quality DOT 4 Brake Fluid, 1 Liter Can
https://a.co/d/hjbM6pa
Your Prestone should be fine to top off, if I was flushing I’d use the stuff good to 536°F.
08 C702.5T (sold)
The non-Swedes:
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Any DOT 4 fluid from local auto parts store is fine.
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
Mercedes-Benz still have DOT4+ available
The MB part# for anyone struggling to find DOT4+ is A000989560509 which supersedes part# A000989560511
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
cn90 wrote: 26 Mar 2024, 21:06 Any DOT 4 fluid from local auto parts store is fine.
Parts store DOT4 is what I use. If I were racing or perhaps lived in mountains, I would use the best stuff.
Has thanked: 1610 times
Been thanked: 4068 times
Pentosin from FCP Is the cheapest to buy. I think I’m on my sixth free can
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
$31.05 - 1 Gallon Johnsen's 5034 Premium Synthetic DOT- 4 Brake Fluid
(www.amazon.com/Johnsens-5034-Premium-Sy ... r=1-2&th=1)
02V70
Post by 02V70 »
I ended up using this stuff from auto zone
It seems to have a higher boiling point than MoVolvo's fluid.
It was the highest boiling point fluid I could find at my local stores. Its ~515 boiling point was still lower than volvos required ~536. I'm not sure if replacing the fluid improved my braking, but it definitely didn't make it worse. I also noticed the pedal feel was a little different.
Screenshot 2024-05-09 165715.png (398.56 KiB) Viewed 1905 times
MoVolvos
Post by MoVolvos »
02V70 wrote: 09 May 2024, 18:02 I ended up using this stuff from auto zone
Are you using for flushing or topping? It's a lot cheaper especially when flushing the system. Not going to see any difference if topping. Have done way way too many brake jobs and the feel (poor) is mostly from dirty fluid with some air or changing to (good) stainless brake lines. The bit of difference in peak temp is negligible unless you are tracking the car and even then good driving won't overheating the system as much.
02V70
Post by 02V70 »
I used it for flushing. I only needed 1L, so it was about $18.
