T6 green injectors
Trevingle
Year and Model: 2008 V70t6p
Post by Trevingle »
Hi . I am in the process of fitting green, ei longer , injectors to my t6. The longer injector to fuel rail mount distance is easily corrected with longer screws and packing piece.. however the fuel line is now too short.
Anybody have experience with this problem ?
Trevingle
Post by Trevingle »
Problem solved. Remove inlet manifold, cut fuel line, add high pressure joiner for required extra length, use spacer on upper line locater on block bringing line closer to fuel rail. Job done
