What gauge wire for a 20A fuse?
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
AlanS
Been thanked: 2 times
Post by AlanS »
I have to rewire the wires going to/ from the fuse box re: my radio. It's the 20A fuse that is accessible when you open the driver's door. It's a complicated issue, but I need to add an in-line 20A fuse. Do I need to consider the gauge wire I use to add a 20A fuse? I ordered a fuse holder with attached wire and it was 12g...very thick, not very pliable to route around things. What gauge wire would be appropriate for use with a 20A fuse? Don't ask about the 'issue'...This will correct it.
br0dy519
Year and Model: 2004 XC70
Has thanked: 126 times
Been thanked: 116 times
Post by br0dy519 »
Electrical code here states 12 gauge for a 20 amp breaker, not sure how that translates to 12V dc in automotive land. Stranded wire would make bends easier. I would think if you're adding a fuse in-line, just splice it in somewhere convenient on the existing wire.
04s60 2.4
04xc70 2.5t
Has thanked: 1506 times
Been thanked: 3822 times
14 AWG or 12awg depending on the wire run.
Here is the chart , note two things
Length is total length, or 2x the piece of wire you cut to run to the load.
10% non critical circuit are resistive loads and lamps
Electronic stuff needs the 3% critical rating
Reference Blue Sea Inc wiring load chart
Year and Model: 2001 V70
Has thanked: 928 times
Been thanked: 1002 times
Post by volvolugnut »
It is best to always use stranded wire for all automotive applications. Solid wire will work harden with vibrations and may break. I have purchased automotive blade type fuse holders with stranded wire ends. Some even have water seal caps over the fuse.
Lug is 100% on point , thanks for catching that. One of the few times it is good to be stranded
