Flashing climate control dash lights - REC & A/C
thegman
Post by thegman »
My 1997 850 T5, with 139,000 miles, started doing something weird a few days ago. I didn't start the car for a couple days, when I did start it, it ran real rough for a about 5 minutes & and the "REC" and "A/C" dash lights flashed in unison exactly 17 times. The next time I started the car, it ran smooth but the lights flashed again (17 times). Now, every time I start the car, they flash 17 times. Any idea what this could be?
Thanks for your help. Andy
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
You need to have the car's fault system codes read. Volvo dealer, independent Volvo mechanic, even some auto parts stores can do this. Tell them it's an OBDII standard interface. Call first to make sure they don't charge you for this.
Also -> Amazon link
thegman
Post by thegman »
Matthew
Thanks for your help. I will follow your advice.
Andy
Paul's 850glt 96
Post by Paul's 850glt 96 »
The arrow light is blinking and engine light is on. The car starts fine but when put into any forward gears, it hardly moves. It goes in reverse fine but not forward...the vehicle crawls. I've given it an ATF flush, since, this problem developed. It was working fine prior and fine just after (the same day of the flush). The next day is when this problem surfaced. Do you have any ideas?
Guest
Post by Guest »
Paul's 850glt 96 wrote:The arrow light is blinking and engine light is on. The car starts fine but when put into any forward gears, it hardly moves. It goes in reverse fine but not forward...the vehicle crawls. I've given it an ATF flush, since, this problem developed. It was working fine prior and fine just after (the same day of the flush). The next day is when this problem surfaced. Do you have any ideas?
[email protected]
