Rear Wiper Washer Nozzle Installation
rntaboy
- Has thanked: 6 times
- Been thanked: 8 times
Anyone know the correct method/have any tips for getting a rear wiper washer nozzle (30634270) to seat fully? Trying to replace my old one, and getting the nozzle into tube it fits into has been a struggle. I already destroyed a new one, and I'm just curious how I was supposed to do this. I have to imagine there must be a better way than just carefully cranking on it back and forth, hoping the nozzle doesn't break off in the process, until it seats 98% of the way.
- darylrobert
- Year and Model: V70 240 740t xc70
- Been thanked: 44 times
No but i found a thread about it....do you not just tap it in? maybe heat the metal tube so it expands and put the plastic nozzle in the freezer??
https://www.swedespeed.com/threads/rear ... nt.651488/
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
The new nozzle will not seat because the original broke off and its still stuck inside.
Remove the new nozzle, now you can extract the old broken peice with a sheet rock screw.
Vova585
- Has thanked: 228 times
- Been thanked: 238 times
Agree with jonesg. Inspect for broken pieces inside of the housing. I think i used small drill bit to clean remanance of mine. You dont have to remove the motor assembly to replace this nozzle. If everything looks good, proceed to install new one. Use dish soap as lubrication. 98% might be all it can do. Possibly there was some change in supplier and it is not 100% accurate length. If it sits tight and sprays in the correct directions(i think it is 2 nozzles there) without leaks around stem and you can close decorative wiper cap-you are most likely as perfect as it gets.
rntaboy
I appreciate everyone trying to help. I'm pretty sure nothing was left behind when removing the original nozzle, shown below, which I was able to pull out with relative ease after hitting it with PB Blaster. I'm also of the mind that it should be fine with how far it is currently seated, I was just curious is anyone knew a "correct" way Volvo might have their techs do for this replacement.
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
Recommendation for anyone stumbling upon this: Delete the rear wiper and install a glass bung. Best decision I ever made after screwing around with this nozzle, then eventually the whole assembly died, gear stripped, etc.
Not worth it. Rear defog now cleans my xc70 rear window. This is the kit I bought. He provided 3 bungs of marginally varying size, adhesive, and easy instructions.
https://www.ebay.ca/itm/163568624666?it ... SwDEtaG-i5
Removed the fuse or relay, can't remember, for the rear washer pump and the wiper arm. Installed a screw and zip tied the water line just in case. Done and looks really slick, I get compliments on it from other Volvo owners. Plus, I don't have to fart around with it anymore
04s60 2.4
04xc70 2.5t
04xc70 2.5t
rntaboy
Update: The problem ended up being that the metal tube the nozzle fits in had become very slightly oblong at some point, preventing the nozzle from easily sliding in. Rounding the opening by inserting the end of a similar diameter punch/pick allowed the nozzle to go in much, much easier.
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
I used a punch, too, after the kid smashed the nozzle with a basket ball.rntaboy wrote: 17 Sep 2025, 02:33 Update: The problem ended up being that the metal tube the nozzle fits in had become very slightly oblong at some point, preventing the nozzle from easily sliding in. Rounding the opening by inserting the end of a similar diameter punch/pick allowed the nozzle to go in much, much easier.
- 2130 Views
Last post by Rattnalle
- 4434 Views
- 971 Views
Last post by silverboy1
- 2399 Views
Last post by darrylrobert
- 5060 Views
Last post by cn90
