Where is this Battery Vent Tube supposed to clip? 2004 V70 Topic is solved
rntaboy
Year and Model: 2004 V70 2.5T
Has thanked: 6 times
Been thanked: 8 times
Post by rntaboy »
The battery vent tube (30668290) on my 2004 V70 was missing the right angle bit that plugs into the battery, so I bought a replacement. I was able to install the new one, but it came with a clip that I can't figure out. Does anyone know where this clip is supposed to clip in the battery compartment?
Been thanked: 504 times
Post by cn90 »
rntaboy
Post by rntaboy »
I'm proud to say I was able to figure out the "attach the vent tube" to the battery part of the install on my own. :D
The part that is giving me trouble is the clip on the plastic loom for the vent tube. I'm not seeing an obvious place where it would clip to the battery compartment of my V70. I'm thinking it might be for some other model that shares the same part, but wanted to ask the forum in case there was a Volvo approved installation location for the clip in question.
Has thanked: 2200 times
Been thanked: 1852 times
That type of clip looks like it clips over a metal pinch weld. If there is none nearby, then you are likely correct it may have been transferred from something else. I don't think either of our P2's has a vent tube at all.
Post by cn90 »
@mtaboy,
If you had spent a bit of time browsing through some YouTube videos, the answer was there. It is in the video I posted above.
rntaboy
Post by rntaboy »
I appreciate your help, Neil! It pointed me in the right direction to the pinch weld. I found a Youtube video (in Swedish) that actually provides a clear image of the intended mounting.
Great detective work!
