Hi Guys,
Got a wierd one. The passenger door appears to be locked but isn't. All the visible signs and sounds are right, key fob actuates, all lock knobs go down and up, everything the same until you pull the handle and the door opens (when apparently locked). The alarm goes off, the whole nine yards.....but the door isn't locked.
Before I tear off the panel and look at the lock mechanism and electric actuator, any ideas or comments? I suspect its either one or the other....like a pin is stuck or broken.
thanks,
oldredwheels.
'00 V70
'99 Expedition
'03 x5, manual
'04 jetta tdi
Door Lock Failure, 2000 V70 SE
oldredwheels
- Year and Model: V70 SE 2000
JRL
- Year and Model: Several
- Been thanked: 16 times
If the lock pops up and down, the arm BROKE inside the door so start removing it
db130
- Year and Model: 2002 V70 T5
My vote is for REPL(Red Evil Plastic Lever) inside the actuator as described here on Volvospeed:
http://volvospeed.com/vs_forum/index.ph ... opic=42326
I had the identical symptoms as your car, the lock knob went up and down each time the lock button was pushed but the door itself failed to lock. However the previous owner of my car had already taken the car to the Volvo dealer(they quoted $270 for new actuator with labor) for the diagnosis.
In my case, a new actuator solved my problem($95 for a factory Volvo actuator from fcpgroton).
2002 V70 T5 169k
2002 V70 NA 249k
2006 Mini Cooper S 90k
2002 V70 NA 249k
oldredwheels
thanks guys,
I'm going ahead with a new actuator. I figure, take the door apart once and fix it for good. 95K miles, it'll break again....
any issues with the hardware holding the door panel on, should I buy any loose parts when I buy the actuator?
oldredwheels
oldredwheels
VCA
- Year and Model: 2008 S80 T6 AWD
- Been thanked: 5 times
You'll probably want a few door clips--I keep 'em on my parts shelf, always break at least one any time I pull the door panel off (turns out my shop does the sameoldredwheels wrote:thanks guys,
oldredwheels
2008 S80 T6 AWD
1999 S70 GLT
1999 S70 GLT
crisleggett
- Year and Model:
Hello, I've have a passenger door lock knob that will not pop with the rest. ive gogt the panel off not sure whagt i'm looking at yet. Any advise?
Thanks
Thanks
JRL
Guess you didn't read the entire post, you need a NEW doorlock/actuator assembly
- 7493 Views
Last post by precopster
- 1264 Views
Last post by JRL
- 1483 Views
Last post by joevar
- 1637 Views
Last post by Clemens
- 489 Views
