Tires
camper guy
- Year and Model:
Friday night I pulled out the four rims and summer tires that came with my car. Turns out 3 of the 4 have "issues" so I need to replace them before inspection. The winter tires are 16's, the ones on the summer rims are 215/70/ZR17. $138 + M,B & each for new Dunlops just like the ones on there. I got a price of $107 complete each for Falcon? Z rated same size. Anyone heard of these? I also was quoted $87 complete each for H rated tires. What is the difference between H & Z? The guy at the tire place said it's higher profile but tires really confuse me.
1995 850 Turbo, IPD chip, 262 HP
rainman
I'm reading this website from Europe so DOUBLE check the info I am giving you is the same in the US. H & Z are speed ratings. If the tires are correctly inflated for high speed driving, the H or Z rating stipulates the maximum speed that the tires should be driven at. In Europe the H rating is up to 130 mph, and the Z is 150mph. Hope this helps..
camper guy
- Year and Model:
I have also been told it's the height of the side wall and flexibility of the rubber. I've been told the "H" rated tires last longer as well. I don't plan to go much over 75 - 80 any time soon so if the speed rating is the only factor I will probably go with the H tires.
rainman
The height of the tyre (profile) compared as a percentage of the width of the tire is the 'aspect ratio' H or Z has nothing to do with this measurement (although for sidewall stiffness and stability reasons, you will not find a 'normal' profile Z rated tire,a s they are primarily used on performance cars).
My tyres are 195/60 R15s meaning the tire size is 195, the height of the tyre sidewall is 60% of its width, the R stands for radial and 15 is the size of the wheel rim in inches.
I hope I haven't told you stuff you know already!
camper guy
- Year and Model:
Thanks, I didn't know all of those things, it makes sense. I don't plan to drive my car at sustanied speeds above 70 any time soon so I think the H rating tires will be fine.
- Has thanked: 2864 times
- Been thanked: 1332 times
guest
215/70/ZR17 ??? Are you sure that they're 70 profiles? That seems like an awfully odd size to fit in the volvo wheel well, and I've never seen Z rated tires with a 70 profile (although that doesn't mean they don't exist).camper guy wrote:Friday night I pulled out the four rims and summer tires that came with my car. Turns out 3 of the 4 have "issues" so I need to replace them before inspection. The winter tires are 16's, the ones on the summer rims are 215/70/ZR17. $138 + M,B & each for new Dunlops just like the ones on there. I got a price of $107 complete each for Falcon? Z rated same size. Anyone heard of these? I also was quoted $87 complete each for H rated tires. What is the difference between H & Z? The guy at the tire place said it's higher profile but tires really confuse me.
- 3284 Views
Last post by SuperHerman
- 2161 Views
Last post by benrk
- 1666 Views
Last post by precopster
- 1130 Views
Last post by rspi
- 943 Views
Last post by sinclair
