Ok, so I posted a few months ago about a slight miss when stopped or leaving a stop. CEL started flashing the other day, so I had codes read. Cyl #4 misfire. Purchased a new coil pack, replaced the fourth one from the passenger side of the engine. Still missing. I know I need to clear my codes, but I'm unsure that I replaced the right coil pack. I still have the old one. Any suggestions?
1999 S70 2.5l n/a 232,000 miles
Cylinder # 4 misfire...
- Has thanked: 17 times
- Been thanked: 35 times
You count 1-2-3-4 from the passenger side of the car towards the driver's to know which coil pack...did you do this?
lewismug
- Year and Model: 1999 S70
Yep. 1234 from passengers side. It had a code for the #4 cylinder AND a pending code for another misfire, didn't specify which cylinder, but was exact same code. Would it throw the same code for different cylinder misfires, or a different one for each cylinder? I guess I need to get them read again, then clear them all and see what comes back.
'99 S70 270k miles--Stock
'00 Audi A4 Quattro 172k miles--Stock
And...you might try swapping the coil to another plug to see if the code comes up for a different cylinder.
SHAKIBOXCARJOE
- Year and Model:
I had the same problem about a year ago. i got new plugs,wires, and a distributer cap and it fixed mine. but i had to get special volvo plugs and wires because i tried to go cheep the first time and it didnt work.
96 850 230k miles 5 spd
- 2836 Views
- 19 Replies
- 10180 Views
Last post by Barledge
- 2491 Views
Last post by Ryanxr400
- 2161 Views
Last post by S40Colorado
- 1269 Views
Last post by ebolanore
