high out put alternator or compacitor; both?
Ian_Griffiths
- Year and Model:
Cali,
You are probably best off looking at an uprated battery, like an Optima Yellow top and a decent capacitor.
My C70, has a Yellow top and a 1 farad cap to drive the RF 1000BD amp @ 2ohms and I only get a slight flicker of the dash light if I am stationary. Before this, I had a definite problem and could see the headlights dim to the beat while driving.
1997 C70 T5 GT Manual - Saffron Pearl
RICA ECU, ITG Filter, Strut Brace, Lowered 30mm
Alpine HU, 2 12" Polk Subs, 1000BD Amp, C70 Plate.
2001 V70 T5 SE Geartronic - Stone Black
RICA ECU, K&N Filter, Custom Stainless Exhaust
Clarion HU, Volvo Sub.
run heavier gauge wire from alt to batt pos. terminal. also run another heavy gauge wire from your neg. terminal to your body. if this does not totally correct the problem then you will need a cap. what it the total power consumption of your system? what are the fuse ratings on your amp? a 1 farad cap is good for storing enough reserve for a system using 800 watts but the cap won't do a lot if the wiring is not heavy enough to carry the load.
- 368 Views
- 877 Views
Last post by cn90
- 575 Views
Last post by drumhead87m
- 632 Views
Last post by mandkbean
- 1305 Views
Last post by anbran1
