reading lights don't turn on in Volvo S80 T6 99
the lights are fine... can some one help me???
Volvo S80 T6 1999
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
Are you talking about the overhead lights in the headliner that shine down on each seat? How do you know the lights are fine if they won't come on? Have you checked the fuses?
vegasjetskier
Are you sure you are pushing the correct switches for the lights? See below:
vegasjetskier
From looking at VADIS, it appears to be #28, but that fuse also powers other things like the Upper Electronic Module and the vanity mirror lights. So, if those things work, it probably is not a fuse that is bad. When you took the lights out to check them, did you notice if there was a ground wire for the light housing?fcani wrote:i pushing the correct switches for the lights but they dont work... can you tell me wath fuse i need check???
vegasjetskier
Here's a pic of the ground strap. If your car has one, make sure it's in place as shown.
i dont find the ground strap...i thinck my car don´t have one...
but you now forghet about it i can live without this ligths...but you can tell me how a take off the cabin fan motor??? the AC compressor works fine just the fan stop i allready check the fuse its fine...
Peace out...
Peace out...
Volvo S80 T6 1999
- Has thanked: 17 times
- Been thanked: 35 times
Might not be the fan but the power pack (resister pack) that is right next to it...it goes and the fan won't work. You can try to put 12V directly to the fan- if it works, then it's the power pack. If it doesn't work, then it's your fan. You can get to your fan by taking the sound proof panel out from right under your glove box...just a couple of screws, I believe.
I just had the same thing happen to my reading lights after I changed my battery.
Have you tried to operate the sunroof? My sunroof wouldn't work either. I removed the fuse that controls the sunroof and the reading lights, re-installed it. And everything worked fine after that.
_________________________________________________
1996 Volvo 850 Platinum - 174,000 miles
2000 Volvo S80 2.9 - 88,000 miles
- Our Volvo family.jpg (53.6 KiB) Viewed 1333 times
2004 Volvo XC90 AWD - 170,000 miles
2010 Volvo XC60 AWD - 145,000 miles
1996 Volvo 850 Platinum - 201,500 miles - KILLED BY UNINSURED DEER _
