I recently started having trouble with my front passenger window not working correctly, it almost seems like it is loose on the mechanism or something. I want to have a look at it but need to know the best way to get the interior door panel off.
Thanks in advance!
removing S80 passenger door interior panel?
- Has thanked: 17 times
- Been thanked: 35 times
Welcome to MVS.
Before starting anything, make sure your car is off and key pulled out of the ignition.
If you'll look around the parameter of your door panel you'll notice little round tabs (6 in all, I think)...there is a post in the middle...push it in with a pen or something small and the tabs will pop out. Other than these, you'll need to pull the triangular piece that covers the side mirror housing off- be careful...you can break the tabs in it, so just pull it straight out. Next, you'll need to undo the screw under a little square tab in the door handle area (what you pull on from the inside to shut the door) and last, use a blunt knife (like butter knife) or a plastic trim/bone tool to pull the trim off from around the door latch itself. Now just lift up the panel and it will come up and off. Be aware that there are connectors in the panel that you may have to disconnect to move the panel out of the way- these are simple and you can reattach them without any problem when you put the door panel back.
bajaman123
- Year and Model: 1999 S80 T6
Thanks for the help! Much appreciated.
Well as soon as I took the panel off and looked inside, the 2 cables that pull the window up and down where tanggled up in the motor wheel. I should be able to get just the cables right? or do I have to buy the entire assembly?
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Looking at VADIS the cables are not separate so it looks like a new unit.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
....or a junk yard. There should be plenty of S80's.
own2volvos
- Year and Model: s80 2000
I have a 2000 s80. Are power window problems common? I had the dealer repair the driver window 2 years ago. It is broken again. Ditto the passenger window. It costs hundreds to fix. Whats up?
I'm interested in your experiences with Weiss and Suntrup. What went wrong?
subdewd wrote:Hey Own2, I see your from STL, have you found a good repair
shop? I had a few bad experience w/brentwood (now weiss)
and west county is a mess. There's an independent on Watson
road but don't know about them.
- 1218 Views
Last post by sergio
- 585 Views
Last post by obayha
- 2685 Views
Last post by Mike Langlois
- 6651 Views
Last post by Polestar
- 1859 Views
Last post by VolvoChef
