2005 s60 Small compenent is hot and making a buzzing noise.
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
vorbosh
Year and Model: s60
Post by vorbosh »
I have buzzing sound comming from below the air filter consol. Down below the air filter is a small aluminum component connected to a hose or wire slightly smaller than a spray paint can lid. It is making the noise when key is set to position 2 (prior to starting). It is also very hot.
Does anyone know what it is called so I can replace it.
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Welcome to MVS.
What you describe is the idle air control, but your description puts it in the wrong place- (as far as I can remember)...and it should buzz. I'm wondering what you're talking about- can you get a picture? Also, you never tell us what car and model year (I assume S60 from your signature...but)- that would be most helpful.
vorbosh
Year and Model: s60
Post by vorbosh »
Thanks so much for replying. The car is a volvo s60 2.4 T 2005. I have attached a picture (in a zip file). The aluminum cylinder in the center is the component causing the noise. The buzzing is loud and was not occurring before.
Thanks again for your help. I googled idle air control and could not find anything looking similar.
volvo 1.zip
(1.75 MiB) Downloaded 304 times
It appears that your car has something that other, earlier Volvo's didn't have- an engine coolant heater. So, I suppose it's suppose to be hot but I have no idea about the buzzing. See if the following instructions show your mystery item:
Engine Coolant Heater.pdf
(1.41 MiB) Downloaded 222 times
