How to change the radiator water and waterpump, volvo s40
Hello could you please send me some instructions on how to change the radiators water, waterpump and which kind of water is best for my volvo s40 1.9 t 2001 with 160000 miles
- Has thanked: 17 times
- Been thanked: 35 times
Oh, no, no, no....not water- you will mess things up... Use Coolant, otherwise known as antifreeze... you can use Volvo coolant or you can use (probably the best for your engine) Zerex G-05 you can find it at Napa...but you'll have to mix with water- use distilled water. The timing belt has to come off to change out the water pump. Instructions from VADIS (Volvo's shop manual) are below in pdf format:
