Thanks
2002 v-70 Turbo problems???
3basecharlie
- Year and Model: 2002 volvo v-70
On several incidents recently when punching the accelerator the car came close to stalling out and on one occassion did stall. I have been told this is due to the turbo not working, I have no previous experience with turbos and I don't know where to start...any suggestions
Thanks
Thanks
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
Normally a stuck turbo won't cause your engine to die, you just will have reduced performance. If you can, remove the intake hose from the compressor housing and reach in gently with a finger and see if you can turn the impeller. If it won't spin, the turbo is stuck. If it does spin, I think your problem lies somewhere else. Can you take the car to a local auto parts chain to have them read the OBD codes with a diagnostic reader?
- 909 Views
Last post by Unclejus1215
- 177 Views
Last post by jonesg
- 1943 Views
Last post by hansenjg
- 2203 Views
Last post by Axe
- 2034 Views
Last post by LiThiuMElectro
