Code P 0305 Cylinder 5 Misfire
SilverBullet
- Year and Model: V70 XC 1999
Does anyone know what this is..? Is it plugs or i heard of the pressure sensor (maybe) Any advice would be nice
- Year and Model: Many Volvos
- Been thanked: 76 times
Bad plugs can cause it as can a bad coil or a bad fuel injector. How does the car run?
If the car is running OK you can often just reset the code.
SilverBullet
the car is running really rough... almost like it's missing.. I will try the plugs first.. Thanks!
SilverBullet
Changed the plugs... Still runs rough... Where is Cylinder 5 located on the engine so i can change coil pack??
5 is the cylinder nearest to the transmission.
SilverBullet
Here is another silly question... The owners manual has the firing order in it and it says 1,2,3,5,4. So does this mean that #5 is second closest to the transmission. I have a new coil pack coming for Cylinder 5.. i just want to make sure i install it on the right cylinder.. Thanks!
The cylinders are lined up in linear fashion.
On a North American car it is
Passenger's side----1--2--3--4--5---Driver's side
The firing order is the order in which the cylinders actually reach TDC on the compression stroke and the spark plug fires.
The codes refer to the actual cylinder location rather than the sequential firing order location.
SilverBullet
Sweet!! Thank you very much Lee!
SilverBullet
So i replaced #5 cylinder coil pack and the car runs great! CEL is off and everything is good.
- 2849 Views
- 1128 Views
- 16 Replies
- 7843 Views
Last post by Supergrunged
- 2584 Views
Last post by Drwanzo
- 971 Views
Last post by pgill
