850 heated seat question
jschick
Post by jschick »
93 850, heated seats don't work. I took 5 min to look at them and plan to repaire Sat.
I get power and it seems like the thermostat is plugged in. my question is do these thermostats come out some how or do I need to remove the seat? it looks like they are plugged in but can only feel them. I assume the thermostat is in the center of the bottom cushion and has a 2 terminal plug onit, does the whole plug generally bust off or just one terminal? basically is this my problem or possibly a busted wire in the top or bottom element? I have not yet taken a ohm meter yet to it but if it is likely the thermostat I may not have to remove the seat, so for you that have repaired them was your plug totaly busted off or what????
any suggestions helpfull
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1253 times
Post by matthew1 »
Seat removal
4 bolts hold it down. They're about 19mm if I recall correctly. Be careful because the nuts are captive and can fall down beneath the floor mount.
Then there's a wire harness or two, and you want to deal with the SIPS (side-impact protection system) correctly so that you don't set it off. You may not have it on a '93. If you do, beneath the plastic shroud that contains the seat controls on the side of the seat you'll see the sensor and a red safety cover to put over it during removal/installation.
The sensor is indeed up inside the bottom cushion. You *may* be able to pull it out to check without taking the seat out. It's a round plastic thing held in place because the foam around it is smaller diameter hold.
Also -> Amazon link
jschick
Post by jschick »
well it was not the thermostat but the heating pad, both seats had busted the wire, generally a easy fix took about 1 hr to repair both seats. nice and warm today, luckly since it was 26degrees here in Ohio this morning
