AC problem - 2001 V70 2.4T
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
mebarsky
Year and Model: 2001 V70 2.4T
Post by mebarsky »
Hello,
My blower fan has stopped working. It worked sporadically for a few days and has now quit completely. I did see an early post on how to change the blower fan. Would this apply here ? How would I check to see if there is an electrical problem ?
Thanks,
Mike
JimLev
Year and Model: S60, V70, 540BMW
Post by JimLev »
My fan (2002 V70 non-turbo) stopped working last spring. I took it out and found that it wouldn't spin freely. I then cleaned off all the dust, put a few drops of oil on the bearings and then connected 12 volts to it and it started working again. I re-installed it and it hasn't failed yet.
mebarsky
Post by mebarsky »
Thanks. I hope it is that simple. I saw a post for an older model showing that the fan was on the passenger side basically behind the glove compartment. Is this where it was for your model ?
JimLev
Post by JimLev »
Yes, that was where it is located. I did take a few pics of the fan when I had it out. If I can find them I will post them.
I did remove the glove box.
IIRC you need torx bits to remove the fan.
mebarsky
Post by mebarsky »
Thanks Jim - looks like I have a nice job on my friday off : )
Cheers
JimLev
Post by JimLev »
Here is the only pic I took of the blower.
