Snow Cables--Too cramped Wheel Wells?
Tire Chains for Snow -- Too cramped Wheel Wells?
2006 S60 2.5T FWD--After all the messages about ill-fitting tires and rubbing when wheels turned lock to lock, who can advise me about size of snow chains/cables before heavy snows in the nearby passes? Any tips on sizing, smaller tires to accommodate chains?
OEMVolvoParts
- Year and Model: ALL
We can sell you the Volvo chains that will fit your car no problem. Provide tire size and we can give you a quote on what they cost. You won't have to worry about them causing any damage.
I would recommend studded tires. If that doesn't cut it maybe a XC 70 or 90 with some clearance would be best for you. The s60's don't have enough clearence to go thru alot of snow and when the body is hung up your are ust going to be spinning those chains and standing still.
Not trying to be pesamistic but although chains will aid in traction, I don't thuink they will help in deep snow.
I want an s60 myself so i'm not knocking the car.
Good luck
Curtis
Good luck
Curtis
2003 v70 2.5tawd black/black 120miles
2007 nissan altima 2.5 cvt 107miles
2001 xc70 211 miles " collision"/ parts car
1994 850 turbo 315miles 5 speed "stoped fixing it"
ctrobk
- Year and Model: V70 2003
Just curious, is there a max speed when using cables/chains?
For me, I need them in my local area (lots of hills), but when I get to the major roads, they are usually cleared by the town/state.
I would hate to have to continually put them on and off.
Thanks
Thanks
Checksix
- Year and Model: V70 T5 2001
- Been thanked: 2 times
Have you considered spiders? Very low clearance so they fit most applications, and very easy on and off. An adaptor stays on the wheel so perhaps not the most aesthetic, but functional excellence.
Jerry
Jerry
01 V70 T5a 175K miles on 3/2016
73 P1800ES 370K miles (RIP)
73 145 about 320K mile (gone with the "X" long ago)
59 Austin Healey Bugeye 2000cc Hemi 150HP
69 F100 (original owner) This truck will RUN FOREVER! (Sold for 2008 F250 diesel in 2013)
velorider
- Year and Model: 2005 S60 T5
- Has thanked: 2 times
- Been thanked: 27 times
I drive to Mammoth here in Los Angeles a few times a year and always bring chain because California is anal about chains with even the lites amount of snow. I try to avoid taking the Volvo only because there is so little room between the wheel well and tire that even running my hands between the fender and wheel is tough.
I have taken the Volvo and have installed cables without issue many time. I just use the SCC snow cables for $23 at Amazon or $50 something every where else and they work fine if installed right, but that goes for any chain. If you are willing to pay the chain guys $20 who cares how difficult it is. I'm not, so I generally don't take the Volvo.
You are right about the wheel stops, most cables wrap the inside and outside of the tire and when turning very sharply the cables will rub against the stops, but this is only an issue in parking lot and such when you turn the wheel all the way.
Reason: added link to Amazon
- 670 Views
Last post by oragex
- 645 Views
Last post by IlikemyXC70
- 82 Replies
- 16719 Views
Last post by prwood
- 4358 Views
Last post by erikv11
- 1458 Views
Last post by amblerman
