Volvo 850 Climate control knob repair.
This topic is in the MVS Volvo Repair Database » Volvo 850 Climate Control Knob Repair
Barn Owl
Year and Model: 850 Turbo '96
Post by Barn Owl »
I had one of my climate control knobs break at the mounting base and I was able to make a quick permanent repair of it. In addition to the broken knob I noticed that the other two were cracked and would fail eventually so I modified them all. The knob's base is an exact fit for a S&W40 caliber spent casing end. I marked the case and then cut it with a hack saw. Slide the brass band over the knobs base and the repair is better than new. The fit is so perfect that no glue is needed. I am attaching a photo to show the repair. I think the photo will do a much better job at explaining this.
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Perfect repair!
I believe this is for the MCC system but please confirm. I would like to add this to the repair database but I want to get it properly categorized.
Barn Owl
Post by Barn Owl »
I have the auto climate control. Is that ecc?
wdckwrth
Year and Model: 855 NA '95
Post by wdckwrth »
Anyone know were to get replacements for the knobs? My passenger side knob has gone missing. (1995 850 with manual climate control)
Post by Ozark Lee »
Welcome to MVS,
You can buy the knobs new from a dealer or you can likely get them salvage from a company like Erie Vo-Vo, they have a link at the top of the page but call them rather than e-mailing them. If you can find one at a local salvage yard then you can save the freight which is likely more than the part itself is worth. If you need other stuff a lot of salvage yards have the "pocket provision" on stuff that they have not yet removed - if it fits in your pocket it is free with any other purchase.
wdckwrth
Post by wdckwrth »
Thanks Lee. I have a line on a local salvage yard. I'll run over there once it warms up a bit around here.
9394volvo850s
Year and Model: 93 850 5spd 94 850T5
Post by 9394volvo850s »
nice job.
93 850 5spd 320k (the daily)
94 850 T5 190K (race car)
95 T-5R wagon yellow (summer wag)
90 745 5spd 295k (winter wag)
67 122 2 door 4spd 69k :))
npharper
Year and Model: 1996 850 GLT Wagon
Post by npharper »
I had the same problem. I did basically the same repair, too, only I used small zip ties and superglue in place of the sawed casings. They seem solid.
PlayGod
Year and Model: 95 850 GLT Vagen 5sp
Post by PlayGod »
Lee, the photo shows ECC knobs. The MCC knobs are completely different shape, and the area in question is not even round. I have a '95 850 GLT Vagen, and I just replaced broken knobs and stripped gears in the MCC (better half turned them "too far").
There is a post on Volvoforums that shows how to remove the MCC... thank goodness I managed to do the repair with parts from a salvage MCC. Removing the MCC cables would have been an extreme hassle.
