Radiator Help
evan023
Year and Model: 2000
Post by evan023 »
Hey you guy have helped me out a lot so far but now i found out my radiator is cracked and I need to find a new one any suggestions my mechanic said it would cost about $300-$350 so if you know of anywhere that i can get one for cheaper please let me know
I have a 2000 S70 T5 or Turbo awd not sure any more
confused_al
Year and Model: 1996 TLA wagon
Post by confused_al »
Call DW Volvo
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
This radiator is only 265 and is a very good one.
Also, if you have your mechanic install it, you will get a lifetime warranty on it.
demian5
Year and Model: 1998 S70 GLT
Post by demian5 »
Is it cracked at the upper radiator hose fitting? Mine is with 133k miles on it. It leaks out only when sitting overnight. I have a new radiator waiting ($170 - I have a connection with a local parts warehouse) and plan on putting it in this weekend, just contemplating replacing the heater core o-rings at the same time...
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
evan023, as far as I know there is no such thing as an AWD s70. To find out, though, look underneath the back of the car and see if you have a rear differential, if you do then you do indeed have an AWD s70.
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
They made an AWD S70 in the model year '99...maybe '00 too. A neighbor had one.
mapaed850
Post by mapaed850 »
Just be sure to get the right radiator. Some have oil coolers and transmission fluid coolers and others don't, even though they may have them listed as being for the same cars. Make sure you know what you need.
demian5
Post by demian5 »
Yeah that radiator I got has the wrong fittings for my oil and transmission cooler lines. My car and original radiator has the clip-on style and the replacement radiator has the screw-on style. Will not work. Need to find another radiator. Things to keep in mind whilst shopping around.
Make sure you get a Nissen if you don't get factory. Then you are sure it will fit.
