borg warner gearbox.
This topic is in the MVS Volvo Repair Database » Borg Warner Gearbox on my 240... or Aisin-Warner?
Sharpy
Post by Sharpy »
My 240 Volvo has the above 3 speed gear box with electronic overdrive (4th) Are they any good and what to look for. Just doing a motor swap and was just wondering, thanks
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
:? That's how I was when I read this. I think you will have the AW70 or AW71 box on your car, not the Borg-Warner which, in 1985, would be the BW55 3 speed without overdrive.
The AW boxes were made by Aisin-Warner, Japan, the first being the AW55 which was the BW55 made under license from Borg-Warner. The AW70 3 speed with overdrive was used in the 1985 240DL/GL and the AW71 3 speed with overdrive was used in the 1985 240GLTurbo (USA). The AW71 is a heavy duty version of the AW70.
Both boxes are good and will notch up high miles if they are serviced according to Volvo specs. On '83 - '85 models the fluid should be changed at 22,500 miles (37,500kms). Initially the service also required the transmission filter to be inspected, cleaned or replaced at the same interval but this was dropped from the service schedule in December 1990.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Sharpy
Post by Sharpy »
Bingo, thanks very much.
