1992 740 turbo////egr problem
The last couple of days my volvo has been idling terribly. When I'm stopped the RPM's will fluctuate from about 1500 to 300. It feels like it is going to die every time. I took it in to a mechanic and they said it was the Air Mass sensor. Didn't fix it. Took it back and they said it was the ECT sensor. Didn't fix it. Took it back again and they said it was something to do with an ignition sensor (mounted above the battery, can't remember what its called). It is still having the same problem as before. I think it might be the EGR valve but not entirely sure. Ideas? Thanks
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Your car is fitted with an On-Board Diagnostic (OBD) unit in the engine compartment. Have you checked for any fault codes? This is a first step in diagnosing problems.
Instructions for the use of the OBD, if you haven't used it before, are in the announcements at the top of this forum.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- billofdurham
It could well be the EGR but a common fault on the B230 engines is a dirty throttle body. It can give the symptoms you are experiencing.
The Swedishbricks FAQ has a very good writeup on the problems and the solution.
Bill.
Bill.
Previously:
Previously:
- 3095 Views
Last post by shaker_chi
- 2478 Views
Last post by regent
