"Bumpy" gear change?
This topic is in the MVS Volvo Repair Database » Bumpy gear change?
tblo760
Year and Model: 760 GLE 1987
Post by tblo760 »
Lots of you seem to be experiencing bumpy changes,and even after the recomended fluid change,the problem still persists.The issue is most definately related to the down-shift cable adjustment.The manuals instruct you to adjust the cable by messuring the distance between the outer cable & 'crimp' this however is only a basic setting,and if the throttle linkage is not 'syncronised' then you will still have problems.The 1st step before any adjustment to the kick down cable,is to check for lost movement in the throttle linkage.By turning the pulley by hand you will see that there is a delay before the 'butterfly' starts to open.This delay means that the down-shift cable is moving before the throttle.So adjust the linkage rod,which has a r/h & l/hand thread at each end to take out all the play,and adjust the kick-down cable so they both start moving together.I've done this adjustment on several AW71 boxes,and it has solved the problem. :mrgreen: :idea:
The way of the wicked is as darkness,they know not at what they stumble,(That's why I'm here to help)
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
Hmmm, this sounds like it should be put in the repair database. :D
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
You are correct and it has been.
tblo760, thank you for this.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
