oil leak
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
safety
Year and Model: 2001 s60
oil leak
Post by safety »
after reading several posts, I'm pretty sure that i have either a cam or crank seal leak. Does any one have any diagrams or
illustrations i can use to change either myself on my 2001 s60?
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
The procedure should be very similar, if not identical, on the S60 engine as this 850 if you're replacing the rear cam seal.
https://www.matthewsvolvosite.com/forums ... =1&t=24925
Now the front (timing belt side of the engine) is a whole different job...let me know if that's the one you need to replace and I'll see what I can dig up for you on that.
'98 S70 T5
2016 Chevy Cruze Premier
safety
Post by safety »
I pulled the cover from the front of the motor today, that's where the leak is coming from. It has dual over head cams.
I'll appreciate any help I can get.
rbodor3
Year and Model: 01 S60 LPT
Been thanked: 2 times
Post by rbodor3 »
how much oil, and what made the crank/cam seals go? Typically they don't just "go bad" especially for your 01
01 Volvo S60 2.4T
jblackburn
Usually the cam seals blow out due to a clogged PCV system.
And bah. The front one's not too bad, but a pain if you've never done it before. The front cam gear (and timing belt) have got to come off, and then you will be able to access and replace the cam seal and crank seal.
If you haven't changed your timing belt, or are coming up on that time, now would be the time to do it and all the associated parts. The VVT on your S60 (my 98 doesn't have it) makes that process a little bit harder to reset on your car, but it's not too involved. Search 'timing belt replacement' for a how-to on this process. I can't find a write-up with pictures to walk you through the process, but this thread as well as the timing belt tutorial on the site here should help you somewhat at least:
http://www.brickboard.com/AWD/volvo/132 ... seals.html
'98 S70 T5
