I changed out the struts, strut mounts, new tires and had the front end aligned. Now Im getting some sort of rattle over bumps. Obvious suspension issue but where??
Someone mentioned to me that sway bar bushings are a common place of wear. Right or wrong?
Ratling noise in suspension
Old Blue 66
- Year and Model: 2001 S60 2.4t
Jimmy Shinyeda
- Year and Model: 1998 S70 T-5
Yea Paul, sway bar endlinks are probably the most common although I had the same problem after putting all new parts(struts,spring seats,endlinks,tie rod ends,brakes, rotors and new calipers) in my 98 S-70 T-5 (104K) and I'm still getting a rattling from the PS side, someone has suggested that my front motor mount is toast (right passenger side) so after exhausting all other options I'm going that route today.(see my post)
Good Luck
Jimmy
Old Blue 66
Its just a rattle when you go over bumps.
Paul
2001 S60 2.4t Owner 117,000 miles
Old Blue 66
Im wondering if the strut mount is loose.Jimmy Shinyeda wrote:Yea Paul, sway bar endlinks are probably the most common although I had the same problem after putting all new parts(struts,spring seats,endlinks,tie rod ends,brakes, rotors and new calipers) in my 98 S-70 T-5 (104K) and I'm still getting a rattling from the PS side, someone has suggested that my front motor mount is toast (right passenger side) so after exhausting all other options I'm going that route today.(see my post)
Good Luck
Jimmy
Paul
Joe Hurless
- Year and Model: e36 328is
The upper engine mount is a common point of failure on this engine as well.
It is also possible that your belly pan was not fully reattached... but it sounds like an engine mount is toast or a swaybar link needs to be replaced. Swaybar links are a very common culprit in Volvo suspension noise. The sound could be described as a "knocking" in the front end over bumps.
CamZH
- Year and Model: '94 850 + '04 S60 R
I've gone old thread digging !
I've got this problem too, did you ever resolve it ?
I'm yet to really investigate, but i've got the knocking over bumps in the front end.
Seems worse when the car is cold ?
2004, S60R
1994, 850 T-5 Wagon
1994, 850 T-5 Wagon
Jack Rock
- Year and Model: 1998 V70R
Yes, mine too. Mine is definitely the control arm bushing found simply by jacking it up and moving the wheel back and forth by grabbing it at 9 and 3 oclock. How important is an alignment after the control arm change? I shouldn't ask because the last time I replaced a tie rod end, I measured and counted and measured some more and still went through a pair of tires in short order.CamZH wrote:Seems worse when the car is cold ?
1997 850 T5 (gave up at 324,000km)
1998 V70 R AWD (gave up at 296,000km)
1998 S70 T5 (total loss - in a parking lot!)
1999 V70XC
1975 VW beetle
1960 Empi Sportster Dune Buggy
1999 V70XC
1975 VW beetle
- 768 Views
Last post by jonchu
- 12 Replies
- 2779 Views
Last post by RickHaleParker
