maintenance
veramayboy
- Year and Model: s60/2001
I just bought a 2001 volvo s60, and i want to know what should i do or what maintenance should i do before i start using it on a regular basis. Can anybody help? Give me a list of things i should do. Thanks.
JDS60R
- Been thanked: 3 times
Change out all of the fluids, the timing belt and put in a set of spark plugs.
The lubricants are the lifeblood of any car. They are usually neglected as Volvo and other manufacturers suggest that some fluids are good for life. They are not.
These cars are also very particular that the timing belt is changed at or before its interval.
Include
Transmission fluid flush, engine oil, Coolant, power steering fluid , Bevel gear if AWD, Haldex or center coupler if AWD and Rear Differential if AWD
Please spend the extra $10 and use Volvo antifreeze and distilled or demineralized water. You should also pay a little more and replace the fluids with Quality synthetics. If you do this all yourself you will save a bunch of money
Then enjoy. I would suggest a fuel filter and injector cleaning for cars with over 80K as well
Include
Retired
Joe Hurless
- Year and Model: e36 328is
^^^^^^^Do that. All of it. Also, check your air filter and micro filter. Micros can get pretty nasty after a good 30k. Your car will love you if you do all this service.
veramayboy
THANKS, SOUNDS LIKE VERY GOOD ADVICE.
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 80 times
- Been thanked: 71 times
Hello, Could you please post the mileage of your new-to-you car. The list of things to do should also include an inspection of the axle boots and brakes. CAUTION: If you're new to car maintenance or want to use a coupon at some service center for a transmission flush PLEASE BE AWARE of the fact that your car needs SPECIAL TRANSMISSION FLUID. Do a search on this topic as negligence will COST YOU DEARLY. Kira
Joe Hurless
Good pint Kira. You need Mobil 3309 atf. Dexron III = no.
- 682 Views
Last post by phils94850
- 882 Views
Last post by aartzer
- 24 Replies
- 5994 Views
Last post by Ben850
- 109 Replies
- 31948 Views
Last post by zoli_m13
- 19 Replies
- 3394 Views
Last post by befarrer
