Large PCV Hose Broke-off
This topic is in the MVS Volvo Repair Database » 2001 XC70 J-Hose Replacement Fix w Photos
milesursogood
Year and Model: 850 T-5, 1997
Post by milesursogood »
large hose that connects to the nipple on the air intake hose
The large right plastic hose that connects to the top nipple on the air intake hose broke-off while I was trying to remove the latter in order to clean it. The nipples are clean, so I'm assuming that the PCV system that is clogged. Smoke still comes out of the dipstick tube when the engine is running. I plan to replace the PCV breathing system kit within the next 2 to 3 weeks. My commute to work is 20 miles R/T daily. Is there danger in my driving the car temporarily w/ the large hose broke-off, just until I got the parts to replace the PCV breathing system kit?
1997 850 T-5 142k miles - Mobil-1
renns
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 6 times
Post by renns »
It may make an oil mess where the oil mist and crankcase gases dump out that broken tube. Mine broke like that, so I spliced on a piece of clear vinyl tube, secured tight with a couple clamps. It's been fine for a more than a year now. You could do something similar, but leave a loose end of the hose hanging down to the bottom of the engine compartment.
Just fixing the tube won't fix the PCV system problems, though, so plan on addressing that ASAP.
1994 850 5-speed wagon, retired at 400,000 km
1998 V70 AWD 5-speed, retired at 358,000 km.
2005 XC70 275,000 km - daily driver
VolvoTurbo850
Year and Model: 1994 850 (T5)
Post by VolvoTurbo850 »
Make sure you use something that is heat resistant.. then you might even be dealing with a lil fire in your engine compartment!
The Fleet
2001 V70 (NA) 2.5
1999 C70 Conv. Turbo 2.3 HPT
1998 S70 Turbo (T5) SE
1994 850 Turbo (T5)
1980 Corvette (Corvolvo)
Previous Possessions: (4) 240's, (1) 740, (9) 850's, (5) 70 Series
Projects on the go: NONE... Yet!
GoinFor300KMi
Year and Model: 1996 Volvo 850 N/A
Post by GoinFor300KMi »
My mother always told me: "Don't put off till tomorrow what can be done today". For variety she would say: "There's no time like the present". She didn't know a thing about Volvos, but she was very wise. I would follow my mother's advice.
Call up FCP, mention MVS for the discount, order the kit. When it arrives, put on your blue gloves and fix that puppy.
claymore850
Year and Model: 850 T5, 244, V70 2.4
Post by claymore850 »
It can be repaired TEMPORALLY with a heat resistant hose (to avoid fire risk). No problems to drive the car just a weeks.
Call FCP Groton. its a cheap part..just tricky to replace, but just needed patience and hand tools.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
If you can still reach where it broke off at, cut back the rubber sheath and just get some high-heat tape.
http://www.dinodirect.com/20mm-280-C-Hi ... ID-15.html
'98 S70 T5
2016 Chevy Cruze Premier
bobbych
Post by bobbych »
mine snapped in the exact same place. I simply used a section of Garden hose and 2 jubilee clips and it is still going strong :lol:
1994 850 TURBO
Metallic Grey
Full Leather
milesursogood
Renns - I'm assuming that your PCV system isn't clogged b/c you've been running the car for over a year. I drove my car yesterday, and the open/broken hose line isn't spewing out oil. I guess it's just dumping crankcase gas out into the air. Based on this, my PCV or oil separator box is clogged that is why the broken hose isn't spewing out oil mist?
renns
Post by renns »
If air comes out the oil filler or dipstick tube, but not out that plastic tube, then your PCV system is plugged. That oil separator box breaths through a small passage in the block, which often gets clogged. I cleaned that passage well when I had the oil pan off for o-ring replacement several months ago.
