Squeaking at timing belt area...what could this be?
rommel0915
- Year and Model: 1995 Yellow 850 T5R
It just started this morning. It is very high pitched and sounds like its coming from the belt area. I'm worried that the timing belt (replaced 15k miles ago)might break while driving. Hopefully this is nothing expensive.
1995 Volvo 850 T5R (Yellow)
1995 Volvo 850 Turbo
thecheat
- Year and Model: 1996 850 Turbo Wagon
Take your accessory belt off and see if the noise goes away. If not, did you replace the idler and tensioner pulleys? You may have a failing bearing on one of those if the noise persists if something on the accessory belt (tensioner, idler, or one of the pumps) isn't the problem.
- Year and Model: Many Volvos
- Been thanked: 76 times
+1
Your instrument cluster will light up like a Christmas tree when you take off the serpentine belt but it will cause no harm.
i had very distinct whistle coming from right above my altinator. Turned out the previous owner tried to replace a vacuum line from the small pcv to the left side the intake with a whimpy line so every time my engine would warm up i would have this annoying sound, after finally looking under the main coolant tube, there it was being sucked so hard it was collapsing on itself and caused that noise...dunno if thats ur problem but i though i would share.
86' 240 GL *Yellow* 350k+ Miles and still goin!
97' 850GLT *Burgundy* 155k+
- 4976 Views
Last post by misha
- 1177 Views
Last post by Cees Klumper
- 5500 Views
Last post by jimmy57
- 23 Replies
- 18231 Views
Last post by jonesg
- 20 Replies
- 17849 Views
Last post by Hurtfeelings
