'93 940 brake light switch access.
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
siemonhg
Year and Model: 940 GLE 1993
Post by siemonhg »
How do I remove the panel under the steering column in order to access the brake light switch at the brake pedal?
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
This should help. The steering wheel has only been removed for clarity.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
siemonhg
Post by siemonhg »
Wow ! That simple. Great ! Thanks again !
funnyrocket
Year and Model: 1994
Post by funnyrocket »
Is there any way you can give me step by step instructions. I'm going to try this myself before I pay way to much to get it done. Thanks in advance.
billofdurham
It is quite easy. The brake light switch sits on a bracket behind the brake pedal. Remove the sound proofing panel as shown above. Follow the instructions attached:
940 brake light switch.pdf
(35.48 KiB) Downloaded 866 times
The reference to the SRS is a safety feature. When working on any electrical system near to air bags disconnect the negative lead of the battery and wait a few minutes before starting work. This prevents accidental deployment of the air bags. Make sure you have the radio code before disconnecting the battery.
When you have the new switch in position it should be adjusted so that the brake lights come on when the pedal is depressed 0.3" to 0.6" or 8 to 14 mm.
Bill.
Previously:
mseidl-77
Year and Model: 93 volvo 940
Post by mseidl-77 »
i am trying to replace the stop light switch on my 93 940, i followed what was said to do but mine is different. it has one plug for wires and the other is a hose, and all the switch i can find for my car are just like the one on your site, please help
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
The hose is probably for the cruise control.
1988 Volvo 760 Turbo Wagon
