I have an S60 TS with 127,000 miles.
Tyre's are part worn on the inner edges but still legal.
After 10k miles of trouble free use, the car has just started to bring on the STC warning light some times followed by the abs service required light.
This only happens when taking right hand bends where the suspension is loaded, I can take left hand bends as hard as i like without a problem .
The STC light flashes then engine power reduces , this disappears if i lift off.
If I continue with taking the turn sharply the STC light comes on solid and the abs warning message and light comes on solid until I have switched off the engine and switch on again which clears the messages.
I do not think the STC - ABS is at fault but could this be the sway bar drop link at fault or some other problem?.
At the last MOT I had an advise that there was slight play in the steering rack .
